Колко кончета е типо 1.6 двувалката
    Fiat Punto 1.4 gt turbo
    Ford Fiesta 1.3 new port
    90 кс при 6250 об/минЕто техническите параметри:Specifications Engine Type .................................................. ......... 149C2.046 Cycles .................................................. ....... 4-cycle Number of cylinders ............................................ 4, in-line Bore x stroke .................................................. 84 x 71.5 mm Engine capacity ................................................ 1585 cm3 Compression ratio .............................................. 9.5 to 1 Maximum torque (ECE) Nm (kgm) .................................. 122 (12.5) at .................................................. ........... 4250 rpm Maximum power (ECE) kW (bhp) ................................... 66 (90) at .................................................. ........... 6250 rpm Timing Overhead camshafts(s) driven by toothed belt; no. of OHC’s ............................................. 2 Inlet opens (BTCD) ............................................. 5° Inlet closes (ABDC) ............................................ 53° Exhaust opens (BBDC) ........................................... 53° Exhaust closes (ATDC) .......................................... 5° Valve clearance for timing check, - inlet and exhaust ............................................ 0.80 mm Valve clearance, cold operation - inlet .................................................. ...... 0.40 ± 0.04 mm - exhaust .................................................. .... 0.50 ± 0.04 mm Fuel supply System Integrated SPI-GM Fuel Injection-Ignition System - Dry air filter whith paper element. - Fuel pump in petrol tank. - Fuel filter in engine compartment. - Pressure regulator and 1 electroinjector located above the throttle valve. - Fuel metering: speed-density air volume measurement (engine rpm, air temperature, absolute pressure in exhaust manifold). - Lambda probe optimises fuel metering. - Idle speed (automatic adjustment by electric motor) ................................... 850±50 rpm - %CO at idle (in exhaust) .................................................. ........................ <0> 75°C ................. 10°±2° Spark plugs: Fiat V4LSR - Fiat V4LS Marelli F7LCR - Marelli F7LC Bosch WR7DC - Bosch W7DC Champion RN9YC - Champion N9YC Spark plug gap .................................................. ........................................ 0.6 - 0.8 mm Transmission Manual gearbox Gear ratios: 1st gear ............................ 3.909 2nd gear ........................... 2.267 3rd gear ........................... 1.440 4th gear ........................... 1.029 Top gear ........................... 0.827 Reverse ............................ 3.909 Final Drive Ratio ................ 16/57 Electrical System Battery Capacity, 20hdischarge rate ......................... 55Ah Cold cranking power (-18°C) ........................ 255A Alternator Output current ............................................. 65A Performance Maximum speeds. Fully laden car after running in, km/h: 1st gear .................................................. .... 48 km/h 2nd gear .................................................. ... 83 km/h 3rd gear .................................................. .... 131 km/h 4th gear .................................................. .... 178 km/h Top gear .................................................. .... 175 km/h Maximum gradeability. Fully laden car, % 1st gear .................................................. ..... 44% 2nd gear .................................................. .... 27% 3rd gear .................................................. ..... 15% 4th gear .................................................. ..... 9% Top gear .................................................. ..... 6.5% Reverse .................................................. ...... 44% Weights Kerb weight .................................................. . 1050 kg Payload .................................................. ....... 500 kg Maximum gross vehicle weight ......................... 1550kg Fuel consumption Fuel consumption according to ECE directives (litres/100 km) Urban cycle .................................................. .. 9.5 Constant speed (90 km/h) .............................. 5.6 Constant speed (120 km/h) ............................ 7.5 Fuel consumption according to standart FTP 75 (litres/100 km) City .................................................. ............. 8.6 Highway .................................................. ....... 6.2 Combined .................................................. ..... 7.5 Capacities Fuel tank capacity ............................................ 51 dm?
      мн ти благодаря
