Грешки Fiat Stilo Abarth 2,4 selespeed 20V
    Здравейте спешно ми трябва отговор за 2 грешки на Fiat Stilo Abarth 2.4 selespeed 20V. След диагностиката се появиха следните грешки : P0100; и P1653 Може ли малко инфо за тях.
    Fiat Stilo abarth!
    Compete to win and lose in order to learn!
    Състезавай се за да печелиш и загуби за да се учиш!
    P0100 OBD-II Trouble CodeTechnical DescriptionMass Air Flow (MAF) Circuit MalfunctionWhat does that mean?Basically this means that there is a problem with the Mass Air Flow (MAF) sensor or circuit. Other MAF sensor circuit DTC trouble codes are P0101, P0102, P0103, and P0104.SymptomsYou will likely not notice any serious drivability problems, although there may be symptoms such as a general decrease in power or sluggishness.CausesA code P0100 may mean that one or more of the following has happened:The MAF may be disconnected, or a wiring connection may be bad The MAF sensor may be faulty Possible SolutionsThe simplest thing to do is to reset the code and see if it comes back. Then start with the cheapest, easiest repair procedures:Verify that the Mass Air Flow Sensor wiring is connected properly and that there are no broken / frayed wires. Unplug and reconnect the MAF wiring harness Check the voltage of the MAF sensor (refer to a repair manual for vehicle specific information) Replace the MAF sensor Иначе казано дебитомер, а другата P1653 е вариатор ,предполагам че има електрическа част(реле например)
