Вчера прочетох компа и ми показа тези грешки Р0420 катализатор 1 и Р0130 Lambda 1 Signal (Pre-Cat.)
Какво значат? Кое от двете е за смяна или и двете?
Време | Сигнал от Lambda 1 (преди кат.) | Сигнал от Lambda 1 (след кат.) | Режим на Lambda 1 (преди кат.) | Режим на Lambda 1 (след кат.) | TAG |
с | V | V | |||
0 | 0,727 | 0,376 | Closed loop | Open loop | |
0,59 | 0,659 | 0,366 | Closed loop | Open loop | |
1,16 | 0,737 | 0,371 | Closed loop | Open loop | |
1,75 | 0,742 | 0,39 | Closed loop | Open loop | |
2,32 | 0,659 | 0,415 | Closed loop | Open loop | |
2,89 | 0,239 | 0,39 | Closed loop | Open loop | |
3,45 | 0,747 | 0,395 | Closed loop | Open loop | |
4,02 | 0,747 | 0,39 | Closed loop | Open loop | |
4,61 | 0,703 | 0,434 | Closed loop | Open loop | |
5,17 | 0,166 | 0,4 | Closed loop | Open loop | |
5,72 | 0,722 | 0,424 | Closed loop | Open loop | |
6,31 | 0,732 | 0,366 | Closed loop | Open loop | |
6,89 | 0,527 | 0,366 | Closed loop | Open loop | |
7,47 | 0,703 | 0,38 | Closed loop | Open loop | |
8,04 | 0,752 | 0,444 | Closed loop | Open loop | |
8,63 | 0,708 | 0,439 | Closed loop | Open loop | |
9,21 | 0,688 | 0,439 | Closed loop | Open loop | |
9,77 | 0,351 | 0,415 | Closed loop | Open loop | |
10,37 | 0,737 | 0,444 | Closed loop | Open loop | |
10,94 | 0,693 | 0,42 | Closed loop | Open loop | |
11,53 | 0,17 | 0,4 | Closed loop | Open loop | |
12,11 | 0,747 | 0,4 | Closed loop | Open loop | |
12,69 | 0,737 | 0,371 | Closed loop | Open loop | |
13,28 | 0,713 | 0,376 | Closed loop | Open loop | |
13,84 | 0,415 | 0,449 | Closed loop | Open loop | |
14,43 | 0,683 | 0,405 | Closed loop | Open loop | |
15,03 | 0,737 | 0,468 | Closed loop | Open loop | |
15,57 | 0,688 | 0,454 | Closed loop | Open loop | |
16,16 | 0,678 | 0,434 | Closed loop | Open loop | |
16,73 | 0,752 | 0,39 | Closed loop | Open loop | |
17,28 | 0,669 | 0,459 | Closed loop | Open loop | |
17,85 | 0,673 | 0,444 | Closed loop | Open loop | |
18,41 | 0,752 | 0,42 | Closed loop | Open loop | |
18,98 | 0,722 | 0,444 | Closed loop | Open loop | |
19,55 | 0,654 | 0,463 | Closed loop | Open loop | |
20,13 | 0,219 | 0,454 | Closed loop | Open loop | |
20,7 | 0,752 | 0,444 | Closed loop | Open loop | |
21,26 | 0,737 | 0,42 | Closed loop | Open loop | |
21,81 | 0,664 | 0,463 | Closed loop | Open loop | |
22,36 | 0,151 | 0,415 | Closed loop | Open loop | |
22,93 | 0,732 | 0,429 | Closed loop | Open loop | |
23,5 | 0,722 | 0,478 | Closed loop | Open loop | |
24,07 | 0,2 | 0,459 | Closed loop | Open loop | |
24,64 | 0,752 | 0,429 | Closed loop | Open loop | |
25,18 | 0,737 | 0,478 | Closed loop | Open loop | |
25,73 | 0,683 | 0,473 | Closed loop | Open loop | |
26,32 | 0,698 | 0,424 | Closed loop | Open loop | |
26,9 | 0,747 | 0,439 | Closed loop | Open loop | |
27,49 | 0,698 | 0,424 | Closed loop | Open loop | |
28,05 | 0,551 | 0,444 | Closed loop | Open loop | |
28,64 | 0,747 | 0,493 | Closed loop | Open loop | |
29,18 | 0,688 | 0,478 | Closed loop | Open loop | |
29,77 | 0,2 | 0,444 | Closed loop | Open loop | |
30,34 | 0,717 | 0,4 | Closed loop | Open loop | |
30,89 | 0,752 | 0,493 | Closed loop | Open loop | |
31,46 | 0,703 | 0,473 | Closed loop | Open loop | |
32,04 | 0,615 | 0,463 | Closed loop | Open loop | |
32,61 | 0,854 | 0,444 | Closed loop | Open loop | |
33,19 | 0,122 | 0,4 | Closed loop | Open loop | |
33,76 | 0,786 | 0,512 | Closed loop | Open loop | |
34,34 | 0,761 | 0,449 | Closed loop | Open loop | |
34,93 | 0,131 | 0,473 | Closed loop | Open loop | |
35,51 | 0,659 | 0,493 | Closed loop | Open loop | |
36,08 | 0,678 | 0,449 | Closed loop | Open loop | |
36,63 | 0,683 | 0,473 | Closed loop | Open loop | |
37,17 | 0,844 | 0,522 | Closed loop | Open loop | |
37,75 | 0,84 | 0,483 | Closed loop | Open loop | |
38,31 | 0,122 | 0,4 | Closed loop | Open loop | |
38,89 | 0,761 | 0,434 | Closed loop | Open loop | |
39,49 | 0,141 | 0,454 | Closed loop | Open loop | |
40,1 | 0,595 | 0,459 | Closed loop | Open loop | |
40,66 | 0,693 | 0,449 | Closed loop | Open loop | |
41,25 | 0,678 | 0,439 | Closed loop | Open loop | |
41,85 | 0,717 | 0,449 | Closed loop | Open loop | |
42,42 | 0,18 | 0,512 | Closed loop | Open loop | |
43 | 0,713 | 0,512 | Closed loop | Open loop | |
43,55 | 0,717 | 0,478 | Closed loop | Open loop | |
44,12 | 0,258 | 0,434 | Closed loop | Open loop | |
44,7 | 0,713 | 0,454 | Closed loop | Open loop | |
45,27 | 0,732 | 0,532 | Closed loop | Open loop | |
45,85 | 0,454 | 0,517 | Closed loop | Open loop | |
46,42 | 0,722 | 0,507 | Closed loop | Open loop | |
46,98 | 0,752 | 0,468 | Closed loop | Open loop | |
47,55 | 0,703 | 0,498 | Closed loop | Open loop | |
48,1 | 0,161 | 0,522 | Closed loop | Open loop | |
48,69 | 0,752 | 0,522 | Closed loop | Open loop | |
49,25 | 0,747 | 0,473 | Closed loop | Open loop | |
49,82 | 0,664 | 0,507 | Closed loop | Open loop | |
50,39 | 0,126 | 0,517 | Closed loop | Open loop | |
50,95 | 0,752 | 0,527 | Closed loop | Open loop | |
51,5 | 0,761 | 0,483 | Closed loop | Open loop | |
52,07 | 0,713 | 0,566 | Closed loop | Open loop | |
52,64 | 0,634 | 0,537 | Closed loop | Open loop | |
53,2 | 0,146 | 0,527 | Closed loop | Open loop | |
53,8 | 0,732 | 0,561 | Closed loop | Open loop | |
54,39 | 0,752 | 0,542 | Closed loop | Open loop | |
54,96 | 0,732 | 0,468 | Closed loop | Open loop | |
55,54 | 0,205 | 0,468 | Closed loop | Open loop | |
56,09 | 0,717 | 0,537 | Closed loop | Open loop | |
56,65 | 0,752 | 0,498 | Closed loop | Open loop | |
57,23 | 0,693 | 0,473 | Closed loop | Open loop | |
57,79 | 0,586 | 0,571 | Closed loop | Open loop | |
58,36 | 0,752 | 0,576 | Closed loop | Open loop | |
58,93 | 0,405 | 0,551 | Closed loop | Open loop | |
59,49 | 0,713 | 0,473 | Closed loop | Open loop | |
60,06 | 0,747 | 0,605 | Closed loop | Open loop | |
60,63 | 0,732 | 0,581 | Closed loop | Open loop | |
61,2 | 0,185 | 0,551 | Closed loop | Open loop | |
61,76 | 0,708 | 0,493 | Closed loop | Open loop | |
62,31 | 0,757 | 0,61 | Closed loop | Open loop | |
62,88 | 0,747 | 0,586 | Closed loop | Open loop | |
63,47 | 0,542 | 0,517 | Closed loop | Open loop | |
64,01 | 0,166 | 0,595 | Closed loop | Open loop | |
64,57 | 0,761 | 0,62 | Closed loop | Open loop | |
65,15 | 0,766 | 0,586 | Closed loop | Open loop | |
65,71 | 0,742 | 0,556 | Closed loop | Open loop | |
66,27 | 0,722 | 0,615 | Closed loop | Open loop | |
66,85 | 0,415 | 0,61 | Closed loop | Open loop | |
67,44 | 0,561 | 0,6 | Closed loop | Open loop | |
68,02 | 0,761 | 0,634 | Closed loop | Open loop | |
68,62 | 0,761 | 0,639 | Closed loop | Open loop | |
69,19 | 0,717 | 0,63 | Closed loop | Open loop | |
69,77 | 0,503 | 0,62 | Closed loop | Open loop | |
70,35 | 0,361 | 0,561 | Closed loop | Open loop | |
70,92 | 0,757 | 0,581 | Closed loop | Open loop | |
71,5 | 0,771 | 0,561 | Closed loop | Open loop | |
72,07 | 0,747 | 0,581 | Closed loop | Open loop | |
72,67 | 0,654 | 0,6 | Closed loop | Open loop | |
73,24 | 0,205 | 0,62 | Closed loop | Open loop | |
73,8 | 0,752 | 0,63 | Closed loop | Open loop | |
74,37 | 0,752 | 0,532 | Closed loop | Open loop | |
74,92 | 0,717 | 0,659 | Closed loop | Open loop | |
75,51 | 0,268 | 0,62 | Closed loop | Open loop | |
76,07 | 0,654 | 0,605 | Closed loop | Open loop | |
76,64 | 0,757 | 0,542 | Closed loop | Open loop | |
77,21 | 0,747 | 0,669 | Closed loop | Open loop | |
77,78 | 0,713 | 0,659 | Closed loop | Open loop | |
78,36 | 0,214 | 0,634 | Closed loop | Open loop | |
78,91 | 0,713 | 0,527 | Closed loop | Open loop | |
79,48 | 0,766 | 0,673 | Closed loop | Open loop | |
80,02 | 0,752 | 0,605 | Closed loop | Open loop | |
80,58 | 0,717 | 0,581 | Closed loop | Open loop | |
81,18 | 0,229 | 0,542 | Closed loop | Open loop | |
81,74 | 0,693 | 0,669 | Closed loop | Open loop | |
82,31 | 0,771 | 0,664 | Closed loop | Open loop | |
82,86 | 0,761 | 0,556 | Closed loop | Open loop | |
83,43 | 0,713 | 0,688 | Closed loop | Open loop | |
83,99 | 0,63 | 0,669 | Closed loop | Open loop | |
84,56 | 0,126 | 0,59 | Closed loop | Open loop | |
85,13 | 0,737 | 0,556 | Closed loop | Open loop | |
85,7 | 0,766 | 0,654 | Closed loop | Open loop | |
86,28 | 0,747 | 0,698 | Closed loop | Open loop | |
86,83 | 0,703 | 0,654 | Closed loop | Open loop | |
87,4 | 0,234 | 0,581 | Closed loop | Open loop | |
87,97 | 0,688 | 0,678 | Closed loop | Open loop | |
88,52 | 0,757 | 0,693 | Closed loop | Open loop | |
89,08 | 0,752 | 0,683 | Closed loop | Open loop | |
89,67 | 0,713 | 0,566 | Closed loop | Open loop | |
90,23 | 0,229 | 0,551 | Closed loop | Open loop | |
90,83 | 0,507 | 0,542 | Closed loop | Open loop | |
91,4 | 0,761 | 0,713 | Closed loop | Open loop | |
91,99 | 0,776 | 0,644 | Closed loop | Open loop | |
92,59 | 0,752 | 0,571 | Closed loop | Open loop | |
93,19 | 0,688 | 0,6 | Closed loop | Open loop | |
93,73 | 0,307 | 0,678 | Closed loop | Open loop | |
94,32 | 0,449 | 0,62 | Closed loop | Open loop | |
94,87 | 0,761 | 0,586 | Closed loop | Open loop | |
95,44 | 0,776 | 0,717 | Closed loop | Open loop | |
95,99 | 0,752 | 0,713 | Closed loop | Open loop | |
96,58 | 0,683 | 0,659 | Closed loop | Open loop | |
97,14 | 0,219 | 0,571 | Closed loop | Open loop | |
97,69 | 0,703 | 0,703 | Closed loop | Open loop | |
98,27 | 0,761 | 0,717 | Closed loop | Open loop | |
98,84 | 0,757 | 0,595 | Closed loop | Open loop | |
99,39 | 0,737 | 0,586 | Closed loop | Open loop | |
99,98 | 0,664 | 0,703 | Closed loop | Open loop | |
100,54 | 0,131 | 0,673 | Closed loop | Open loop | |
101,11 | 0,747 | 0,688 | Closed loop | Open loop | |
101,68 | 0,757 | 0,634 | Closed loop | Open loop | |
102,24 | 0,752 | 0,722 | Closed loop | Open loop | |
102,79 | 0,717 | 0,708 | Closed loop | Open loop | |
103,38 | 0,439 | 0,659 | Closed loop | Open loop | |
103,93 | 0,151 | 0,63 | Closed loop | Open loop | |
104,5 | 0,752 | 0,722 | Closed loop | Open loop | |
105,08 | 0,766 | 0,722 | Closed loop | Open loop | |
105,64 | 0,732 | 0,595 | Closed loop | Open loop | |
106,2 | 0,698 | 0,59 | Closed loop | Open loop | |
106,78 | 0,131 | 0,683 | Closed loop | Open loop | |
107,33 | 0,732 | 0,649 | Closed loop | Open loop | |
107,88 | 0,766 | 0,742 | Closed loop | Open loop | |
108,45 | 0,752 | 0,717 | Closed loop | Open loop | |
109 | 0,727 | 0,713 | Closed loop | Open loop | |
109,58 | 0,693 | 0,59 | Closed loop | Open loop | |
110,15 | 0,229 | 0,659 | Closed loop | Open loop | |
110,72 | 0,449 | 0,673 | Closed loop | Open loop | |
111,3 | 0,752 | 0,717 | Closed loop | Open loop | |
111,87 | 0,752 | 0,713 | Closed loop | Open loop | |
112,45 | 0,732 | 0,688 | Closed loop | Open loop | |
113,02 | 0,693 | 0,59 | Closed loop | Open loop | |
113,59 | 0,151 | 0,703 | Closed loop | Open loop | |
114,16 | 0,688 | 0,708 | Closed loop | Open loop | |
114,72 | 0,766 | 0,708 | Closed loop | Open loop | |
115,29 | 0,757 | 0,644 | Closed loop | Open loop | |
115,84 | 0,732 | 0,732 | Closed loop | Open loop | |
116,41 | 0,683 | 0,717 | Closed loop | Open loop | |
116,99 | 0,17 | 0,669 | Closed loop | Open loop | |
117,57 | 0,678 | 0,639 | Closed loop | Open loop | |
118,15 | 0,757 | 0,673 | Closed loop | Open loop | |
118,71 | 0,761 | 0,678 | Closed loop | Open loop | |
119,29 | 0,747 | 0,737 | Closed loop | Open loop | |
119,86 | 0,659 | 0,703 | Closed loop | Open loop | |
120,42 | 0,185 | 0,634 | Closed loop | Open loop | |
120,99 | 0,683 | 0,717 | Closed loop | Open loop | |
121,54 | 0,761 | 0,732 | Closed loop | Open loop | |
122,11 | 0,757 | 0,659 | Closed loop | Open loop | |
122,68 | 0,742 | 0,698 | Closed loop | Open loop | |
123,25 | 0,683 | 0,722 | Closed loop | Open loop | |
123,81 | 0,205 | 0,708 | Closed loop | Open loop | |
124,39 | 0,141 | 0,634 | Closed loop | Open loop | |
124,96 | 0,752 | 0,678 | Closed loop | Open loop | |
125,51 | 0,776 | 0,708 | Closed loop | Open loop | |
126,11 | 0,757 | 0,625 | Closed loop | Open loop | |
126,69 | 0,708 | 0,727 | Closed loop | Open loop | |
127,26 | 0,59 | 0,688 | Closed loop | Open loop | |
127,81 | 0,141 | 0,649 | Closed loop | Open loop | |
128,41 | 0,752 | 0,683 | Closed loop | Open loop | |
128,96 | 0,752 | 0,678 | Closed loop | Open loop | |
129,55 | 0,737 | 0,727 | Closed loop | Open loop | |
130,12 | 0,644 | 0,713 | Closed loop | Open loop | |
130,66 | 0,166 | 0,605 | Closed loop | Open loop | |
131,23 | 0,742 | 0,737 | Closed loop | Open loop | |
131,8 | 0,761 | 0,737 | Closed loop | Open loop | |
132,35 | 0,732 | 0,742 | Closed loop | Open loop | |
132,91 | 0,586 | 0,722 | Closed loop | Open loop | |
133,46 | 0,166 | 0,625 | Closed loop | Open loop | |
134,01 | 0,732 | 0,732 | Closed loop | Open loop | |
134,56 | 0,761 | 0,713 | Closed loop | Open loop | |
135,12 | 0,752 | 0,678 | Closed loop | Open loop | |
135,67 | 0,722 | 0,717 | Closed loop | Open loop | |
136,23 | 0,195 | 0,664 | Closed loop | Open loop | |
136,8 | 0,693 | 0,63 | Closed loop | Open loop | |
137,35 | 0,757 | 0,747 | Closed loop | Open loop | |
137,92 | 0,757 | 0,747 | Closed loop | Open loop | |
138,5 | 0,727 | 0,703 | Closed loop | Open loop | |
139,07 | 0,478 | 0,6 | Closed loop | Open loop | |
139,64 | 0,293 | 0,713 | Closed loop | Open loop | |
140,22 | 0,752 | 0,752 | Closed loop | Open loop | |
140,79 | 0,757 | 0,752 | Closed loop | Open loop | |
141,37 | 0,747 | 0,717 | Closed loop | Open loop | |
141,92 | 0,664 | 0,673 | Closed loop | Open loop | |
142,49 | 0,17 | 0,708 | Closed loop | Open loop | |
143,05 | 0,752 | 0,752 | Closed loop | Open loop | |
143,62 | 0,757 | 0,752 | Closed loop | Open loop | |
144,22 | 0,732 | 0,737 | Closed loop | Open loop | |
144,77 | 0,688 | 0,634 | Closed loop | Open loop | |
145,36 | 0,151 | 0,717 | Closed loop | Open loop | |
145,92 | 0,722 | 0,747 | Closed loop | Open loop | |
146,47 | 0,757 | 0,752 | Closed loop | Open loop | |
147,06 | 0,757 | 0,703 | Closed loop | Open loop | |
147,63 | 0,664 | 0,761 | Closed loop | Open loop | |
148,17 | 0,195 | 0,693 | Closed loop | Open loop | |
148,73 | 0,654 | 0,693 | Closed loop | Open loop | |
149,27 | 0,757 | 0,771 | Closed loop | Open loop | |
149,83 | 0,761 | 0,678 | Closed loop | Open loop | |
150,41 | 0,752 | 0,713 | Closed loop | Open loop | |
150,98 | 0,669 | 0,757 | Closed loop | Open loop | |
151,53 | 0,141 | 0,678 | Closed loop | Open loop | |
152,1 | 0,732 | 0,659 | Closed loop | Open loop | |
152,67 | 0,766 | 0,732 | Closed loop | Open loop | |
153,28 | 0,752 | 0,713 | Closed loop | Open loop | |
153,84 | 0,742 | 0,732 | Closed loop | Open loop | |
154,41 | 0,664 | 0,757 | Closed loop | Open loop | |
154,98 | 0,136 | 0,717 | Closed loop | Open loop | |
155,55 | 0,673 | 0,664 | Closed loop | Open loop | |
156,12 | 0,757 | 0,805 | Closed loop | Open loop | |
156,68 | 0,761 | 0,8 | Closed loop | Open loop | |
157,25 | 0,742 | 0,776 | Closed loop | Open loop | |
157,82 | 0,703 | 0,659 | Closed loop | Open loop | |
158,38 | 0,405 | 0,713 | Closed loop | Open loop | |
158,95 | 0,673 | 0,586 | Closed loop | Open loop | |
159,53 | 0,771 | 0,673 | Closed loop | Open loop | |
160,07 | 0,776 | 0,703 | Closed loop | Open loop | |
160,68 | 0,752 | 0,708 | Closed loop | Open loop | |
161,24 | 0,713 | 0,693 | Closed loop | Open loop | |
161,82 | 0,253 | 0,581 | Closed loop | Open loop | |
162,39 | 0,727 | 0,664 | Closed loop | Open loop | |
162,95 | 0,752 | 0,737 | Closed loop | Open loop | |
163,52 | 0,747 | 0,747 | Closed loop | Open loop | |
164,07 | 0,693 | 0,693 | Closed loop | Open loop | |
164,64 | 0,688 | 0,649 | Closed loop | Open loop | |
165,19 | 0,752 | 0,752 | Closed loop | Open loop | |
165,74 | 0,703 | 0,717 | Closed loop | Open loop | |
166,31 | 0,488 | 0,717 | Closed loop | Open loop | |
166,87 | 0,234 | 0,449 | Closed loop | Open loop | |
167,44 | 0,742 | 0,825 | Closed loop | Open loop | |
168,03 | 0,747 | 0,815 | Closed loop | Open loop | |
168,59 | 0,732 | 0,757 | Closed loop | Open loop | |
169,14 | 0,59 | 0,732 | Closed loop | Open loop | |
169,71 | 0,503 | 0,561 | Closed loop | Open loop | |
170,29 | 0,761 | 0,844 | Closed loop | Open loop | |
170,84 | 0,766 | 0,83 | Closed loop | Open loop | |
171,44 | 0,742 | 0,81 | Closed loop | Open loop | |
172,03 | 0,708 | 0,766 | Closed loop | Open loop | |
172,59 | 0,503 | 0,722 | Closed loop | Open loop | |
