4WD - Four Wheel Drive 4WS - Four Wheel Steering ABC - Active Body Control ABS - Anti Blokier System AC - Air Condition ACC - Active Cruise Control AGS - Adaptive Gearbox Shift ALB - Anti Lock Braking ASC - Automatic Stability Control ASC+T - Automatic Stability and Traction Control ASMS- Automatic Stability Management System ASR- Anti Schlupf Regelung ATM -Adaptive Transmission Management AUC -Automatische Umluft Control AWD- All Wheel Drive BAS -Brake Assyst BST -Battery Safety Terminal CAN- Controller Area Network CDI - Common-rail Diesel Injection CFI -Central Fuel Injection CNG -Compressed Natural Gas CVT- Continously Variable Transmission DBC -Dynamic Brake Control dCi -diesel Commonrail injection (Renault) DDE -Digital Diesel Electronics DISA -Differenzierte Sauganlage sistem DOHC- Double Over Head Camshaft DME- Digital Motor Electronics DSA -Dynamic Stability Assistance DSC -Dynamic Stability Control DSTC- Dynamic Stability & Traction Control dTi ..-dizel Turbo intercooler DTI -Dizel Turbo Intercooler EBD -Electronic Brakeforce Distribution EBV- Elektronische Bremskraft Verteilung ECU-Engine Control Unit EDC -Electronic Damper Control EDC -Electronic Diesel Control EDS -Elektronische Differencialsperre EFI- Electronic Fuel Injection EG- European Gas EGR- Exhaust Gas EMC -ElectroMagnetic Compatibility EPS -Electronic Power Steering ESP -Electronic Stability Program ETC -Electronic Traction Control ETS- Electronic Tracion System EV -Electric Vehicle FDR- Fahr Dynamik Regelung FFV- Flexible Fuel Vehicle FIRE -Fully Integrated Robotized Engine F.I.R.S.T.- Fully Integrated Road Safety Technology FPS -Fire Protecting System GDI- Gasoline Direct Injection (Mitsubishi) GPS -Global Positioning System HDC- Hill Descent Control HDi .- High-pressure Direct Injection HP -Horse Power HPi -... ... injection i, I- Injection IC- Inflatable Curtain ICIM -Individual Control Intake Mainfold IMS- Instant Mobility System IRD -Intermediate Reduction Drive ISOFIX -International Standard Organization FIX ITS -Inflatable Tubular Structure JTD- uniJet Turbo Diesel KW- Kilowatt LSD -Limited Slip Differential MPI- Multi Point Injection NGV- Natural Gas Vehicle OBD- On Board Diagnostic PDC- Park Distance Control PES -Poli Elipsoid System PPD- Passenger Presence Detection PRS- Programmed Restraint System SIPS -Side Impact Protection System SDI- Standard Diesel Injection SMH- Societe de Microelectronique et d’Horlogerie SOHC- Single Over HeadCamshaft SPI -Single Point Injection SRS -Supplemental Restraint System STC -Stability & Traction Control TC -Traction Control TCS- Traction Control System TDI- Turbo Diesel VANOS- Variable Nockenwelle Steuerung VDC -Vehicle Dynamic Control VIS -Variable Induction System VTEC- Variable valve Timing and lift Electronic Control system VVT-i Variable Valve Timing - intelligent WHIPS -WHiplash Protection System WET W- Engineered TreadВзето е от други форуми
Съкращения и абривиатури, използвани при автомобилите
Mescalin написа:урааа ...а може ли тук да питам каква е разликата между SX , ELX и другите буквички които идват след модела на фиат?Alfa Romeo 159 1.9 JTDM'07
Fiat Linea 1.3 Multijet'08
http://forum.fiat-bg.org
Sko написа:Добра е колекцийката Само една забележка имам: ABS - Anti-lock Braking SystemJeep Grand Cherokee 3.1 TD Limited '01
Alfa Romeo 156 1.9 JTD SW Dinstinctive '02
ex Alfa Romeo 166 2.4 JTD '99
pinko168 написа:Sko написа:Добра е колекцийката Само една забележка имам: ABS - Anti-lock Braking Systemex'Fiat Tipo | ex'Lancia Dedra 2.0 | ex'Alfa 155 1.7TS | ex'98 Lancia Dedra 1.9td SW | ex'ALFA 164 2.0TS | ex'Lancia Delta 1.6i | ex'Fiat Coupe 1.8 16V VFD | ex'Fiat Bravo 2.0 20V HGT
Abarth. написа:pinko168 написа:Sko написа:Добра е колекцийката Само една забележка имам: ABS - Anti-lock Braking SystemJeep Grand Cherokee 3.1 TD Limited '01
Immortal написа:И "I" то ли в двете абревиатури е еднакво ?За какво междинно охлаждане (intercooling) става въпрос в двигателя без турбо?Jeep Grand Cherokee 3.1 TD Limited '01
