emzo написа:
Лаптопа се изключи сам.
u_bo
u_bo
как да разбереш?1 - хвани някаква закономерност на проблема2 или наистина може да опиташ със съвета за хузкрашед
u_bo
Tornado написа:null.zero написа:колега Торнадо ти нарочно ли ме игнорираш?
Във въпросната папка има три файла които са с датите на проблемите точно.До колкото виждам и разбирам проблема идва от антивирусната AVG.Analysis--------------------------------------------------------------------------------Crash dump directory: C:WINDOWSMinidumpCrash dumps are enabled on your computer.On Tue 10.2.2009 г. 19:27:50 your computer crashedThis was likely caused by the following module: avgtdix.sysBugcheck code: 0x1000000A (0x166, 0x2, 0x0, 0x804FAADA)Error: Unknownfile path: C:WINDOWSsystem32driversavgtdix.sysproduct: AVG Internet Securitycompany: AVG Technologies CZ, s.r.o.description: AVG Network connection watcherOn Wed 04.2.2009 г. 17:29:12 your computer crashedThis was likely caused by the following module: avgtdix.sysBugcheck code: 0x1000000A (0x166, 0x2, 0x0, 0x804FAADA)Error: Unknownfile path: C:WINDOWSsystem32driversavgtdix.sysproduct: AVG Internet Securitycompany: AVG Technologies CZ, s.r.o.description: AVG Network connection watcherOn Wed 04.2.2009 г. 07:13:17 your computer crashedThis was likely caused by the following module: avgtdix.sysBugcheck code: 0x1000000A (0x166, 0x2, 0x0, 0x804FAADA)Error: Unknownfile path: C:WINDOWSsystem32driversavgtdix.sysproduct: AVG Internet Securitycompany: AVG Technologies CZ, s.r.o.description: AVG Network connection watcher--------------------------------------------------------------------------------Conclusion--------------------------------------------------------------------------------3 crash dumps have been found and analyzed. Note that it’s not always possible to state with certainty whether a reported driver is really responsible for crashing your system or that the root cause is in another module. Nonetheless it’s suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.Fiat Bravo 1,4 12V; Lancia Zeta 2,0 Turbo; Fiat Doblo 1,9 Multijet 120 h.p.
