Съкращения, които може да са Ви от помощ --------------------------------------------------------------------------------4WD - Four Wheel Drive4WS - Four Wheel Steering ABC - Active Body Control ABS - Anti Blokier System AC - Air Condition ACC - Active Cruise Control aktivni ADS - Adaptive Dämfung System AGS - Adaptive Gearbox Shift ALB - Anti Lock Braking ASC - Automatic Stability Control ASC+T - Automatic Stability and Traction ControlASMS - Automatic Stability Management System ASR - Anti Schlupf Regelung ATM - Adaptive Transmission Management AUC - Automatische Umluft Control AWD - All Wheel Drive BAS - Brake Assyst BST - Battery Safety Terminal CAN - Controller Area Network CDI -... Diesel Injection (Mercedes-Benz) CFI - Central Fuel Injection CNG - Compressed Natural Gas CVT - Continously Variable Transmission DBC - Dynamic Brake Control dCi - diesel Commonrail injection (Renault) DDE - Digital Diesel Electronics DISA - Differenzierte Sauganlage sistem DOHC - Double Over Head Camshaft DME - Digital Motor Electronics DSA - Dynamic Stability Assistance DSC - Dynamic Stability Control DSTC - Dynamic Stability & Traction Control dTi - dizel Turbo intercooler DTI - Dizel Turbo Intercooler EBD - Electronic Brakeforce Distribution EBV - Elektronische Bremskraft Verteilung ECU - Engine Control Unit EDC - Electronic Damper Control EDC - Electronic Diesel Control EDS - Elektronische Differencialsperre EFI - Electronic Fuel Injection EG - European Gas EGR - Exhaust Gas EMC - ElectroMagnetic Compatibility EPS - Electronic Power Steering ESP - Electronic Stability Program ETC - Electronic Traction Control ETS - Electronic Tracion System EV - Electric Vehicle FDR - Fahr Dynamik Regelung FFV - Flexible Fuel Vehicle FIRE - Fully Integrated Robotized Engine F.I.R.S.T. - Fully Integrated Road Safety Technology FPS - Fire Protecting System GDI - Gasoline Direct Injection (Mitsubishi) GPS - Global Positioning System HDC - Hill Descent Control HDi - Diesel injection (Citroën, Peugeot) HP - Horse Power HPi -... ... injection i, I - Injection direkten vbrizg goriva IC - Inflatable Curtain ICIM - Individual Control Intake Mainfold IMS - Instant Mobility System IRD - Intermediate Reduction Drive ISOFIX - International Standard Organization FIX ITS - Inflatable Tubular Structure JTD - uniJet Turbo Diesel turbo dize KW - Kilowatt MPI - Multi Point Injection NGV - Natural Gas Vehicle vozilo na naravni plin OBD - On Board Diagnostic PDC - Park Distance Control PES - Poli Elipsoid System PPD - Passenger Presence Detection PRS - Programmed Restraint System SIPS - Side Impact Protection System SDI - Standard Diesel Injection SMH - Societe de Microelectronique et d’Horlogerie SOHC - Single Over HeadCamshaft SPI - Single Point Injection SRS - Supplemental Restraint System STC - Stability & Traction Control TC - Traction Control TCS - Traction Control System TDI - Turbo Diesel VANOS - Variable Nockenwelle Steuerung VDC - Vehicle Dynamic Control VIS - Variable Induction System VTEC - Variable valve Timing and lift Electronic Control system VVT - Variable Valve Timing - intelligent WHIPS - WHiplash Protection System WET W - Engineered Treadето малко инфо за дизелите копирано от форума на Нисан * TDI (Turbodiesel Direct Injection): VW, Audi, Seat, Skoda* TDI PD: PD = Pumpe-Düse* DTI (Direct Turbo Injection): Opel* dTI (Direct Turbo Injection): Renault* TDCi (Turbodiesel Common Rail Injection): Ford* TDDI (Turbo Diesel Direct Injection): Ford* i-CTDi (intelligent Common Rail Turbo Diesel Injection): Honda* CDTI (Common Rail Diesel Turbo Injection): Opel* CDI (Common Rail Direct Injection): Mercedes-Benz, Daimler-Chrysler* CRDi (Common Rail Direct Injection): Hyundai* JTD (Jet Turbo Diesel): Fiat, Alfa-Romeo (Common-Rail)* dCi (Diesel Common-Rail Injection): Renault, Nissan* HDi (High Pressure Direct Injection): Peugeot, Citroën (Common-Rail)* DI-D (Direct Injection Diesel): Mitsubishi (Common-Rail)* D-4D (Direct Injection 4-stroke Diesel): Toyota (Common-Rail)* DDIS: Suzuki (Common-Rail)
И още веднъж за съкращенията
