Малко труден избор.Ако може малко Support?
    Някой ползвал ли ги е ?малко отзиви към марката?Положителни.Отрицателни.Кой комплект е добър.Че малко не ги разбирам тия цифри и обозначения.Ако може някой да ми ги обясни, или да ме прехвърли към някоя темичка с обозначенията.Благодаря Ви! Ето този ?Артикул:LANZAR VX694Описание:Standard 6’’ x 9’’ Size Fits OEM Locations Poly-Mica Coated Woofer Cone 1.25’’ High Temperature Voice Coil Neodymium Dome Tweeter .75’’ Film Cone Tweeter Film Cone Midrange Power Handling: 200 Watts RMS/400 Watts Max Impedance: 4 Ohms Frequency Response: 41-22kHz Rubber Boot Magnet Cover Mounting Depth: 3.11’’ Includes Grills, Wires and Installation Hardwarehttp://www.k99bg.com/Default.asp?Operation=2&Art_ID=LANZAR%20VX694Тоя?L ANZAR VX830Описание:Standard 8’’ Size Fits OEM Locations Poly-Mica Coated Woofer Cone 1.5’’ High Temperature Voice Coil Neodymium Dome Tweeter Film Cone Midrange Power Handling: 200 Watts RMS/400 Watts Max Impedance: 4 Ohms Frequency Response: 37-22kHz Rubber Boot Magnet Cover Mounting Depth: 3.35’’ Includes Grills, Wires and Installation Hardwarehttp://www.k99bg.com/Default.asp?Operation=2&Art_ID=LANZAR%20VX830Или тоя?Артикул:LANZAR HR5.1Описание:One Pair Midrange: 5.25’’ Midrange Driver Chromed Mica-Poly Cone Butyl Rubber Surround 120 Watts RMS/ 240 Watts Peak Frequency Response: 80-8KHz Impedance: 4 OhmsOne Pair Tweeter: 1’’ Silk Dome Tweeter Neodymium Magnet 3 Mounting Options: Flush / Swivel / Surface or Angle Mount Frequency Response: 1.4-24KHz Impedance: 4 OhmsOne Pair Passive Crossover Network: Two-Way Passive Crossovers 12dB Octave Slope Gold Plated Connectors Fully-Protected CircuitryAccessories: Custom Grills Mounting Hardware Wiring Kit w/Diagram & Templatehttp://www.k99bg.com/Default.asp?Operation=2&Art_ID=LANZAR%20HR5.1Или пък може би този?LANZAR OPTI6.1Описание:This Custom Kit Contains:One Pair Aluminum Cone Mids: 6.5’’ Midrange Driver Aluminum Alloy Cone Butyl Rubber Surround 200 Watts RMS/ 400 Watts Peak Frequency Response: 55-6KHz Impedance: 4 Ohms One Pair Plastic Caseing Tweeters: 1’’ Silk Dome Tweeter Neodymium Magnet 3 Mounting Options: Flush/Swivel/Surface/Angle Mount Frequency Response: 1.4-24KHz Impedance: 4 OhmsOne Pair Passive Crossover Network: Two - Way passive Crossovers 12dB Octave Slope Gold Plated Connectors Fully-Protected CircuitryIncluded Accessories: Custom Grills Mounting Hardware Wiring Kit Wiring Diagram & Templatehttp://www.k99bg.com/Default.asp?Operation=2&Art_ID=LANZAR%20OPTI6.1
    Като гледам никой не отговори на темата ти. Все пак купи ли си нещо на Ланзар, питам понеже ми ги предложиха в един магазин, а са на цената на блаупункт от т. маркет, който е много вероятно китайски. За тези разбрах, че са американско производство, а и като разгледах и в официалния им сайт и изглеждат добри.
    156 sportwagon 1,9 jtd 115
      Колега по добре ако искаш да вземаш нещо скъпо качествено вземи DLS шведско производство са много добри говорители правят и не само.Лензар също е добра марка.
      Fiat Bravo 1.4 12v Turbo Makaron
